Betrayer00GT
- Feb 25, 2007
I have been building systems for myself and others since the late 90's, when my dad financed my first system. I have never put together an OCed setup for anyone (even myself) in all that time, however. I had a "celery" 300a back in the day, and I admit I tried it at 450, but mine wouldn't even post. Two of my friends had them running at 450, but I guess the OC gods just wouldn't smile for me back then.
I guess that first experience contributed to my ongoing OC ambivalence.
Well, ambivalence is ongoing no longer. My roommate got Supreme Commander for his Alienware E6700-based system a couple days ago. That game is my new calling.
"The system that can handle this game with everything enabled has yet to be built." - GameSpot reviewer
Oh, it is so "on" now. lol
Backstory (Feel free to skip to "The Lowdown")
So, before Supreme Commander upset my OC sensibilities, I had started a new system project (with an eye for future-proofing and potential future overclocking, thank God). My trusty XP 2000+ system, from so long ago I don't even remember anymore, went down due to a hardware problem. It it had been able to do everything I wanted from it. HL2, Doom3 (barely on this one, but it did it), the various Dawn of War releases, plus all the productivity apps I use were all fine on this ancient chimera. I decided to rebuild it, but with a water cooling setup (for noise control, not performance).
So, back at the end of November, I decided to put a water cooling loop in it before fixing the hardware failure. I tore it apart and packed up the components. I then used my router, angle grinder, and Dremel to get a stealth WC install (using DangerDen blocks/rad and a small AC pump) into my old school, all-aluminum Cooler Master ATC-100 case.
The thing is, when I got to pricing the parts to fix the H/W failure (after the month and a half it took me to get through the case modding for the WC install), I found other parts of my budget (the WC setup and Mustang upgrade parts/labor) killed my ability to order any replacement parts for a while. This went on until a week ago, when a family member (who got sick of hearing me whine about not being able to play games on my Moto Q or employer issued laptop, and) made an offer out of the blue to pick up ~$1200 in parts, if I get them from Dell, should I be interested.
I was.
So, Dell sucks as a motherboard supplier. They only sell (as far as I can tell) the DG965WH, and I have ordered it and a Core 2 Duo CPU. Other than motherboard selection, this Dell Accessories experience has been pretty good. Well, at least it was not as bad as I was expecting when that offer was first made.
Starting with such a horrible motherboard (for any kind of OC) is going to suck, but not too badly. It will take me a while to be able to replace it with an enthusiast board, but I guess I can just hang for a while at stock speeds. I do not want to try to OC anything immediately anyway. Even if I had the enthusiast board immediately, it could take me some time to get a new Lucite top for my Maze4 CPU block (I need a 775 top as it has a Socket-A ATM), and then change the tubing to work with any new motherboard's layout.
I actually haven't even decided I will configure the loop for this initial Intel board's layout when I don't need the extra cooling vs air at stock speeds. Also, since I will be switching to an enthusiast board later, do I want to have to potentially redo tubing with yet another MB layout? We'll see. It will come down to how loud the stock cooling is, I guess. Anyway, at least my Maze5 GPU block will work on an nVidia 7-series, and I even ordered the hardware for that, initially. Again though, regardless my WC loop status, any system on the Intel board will be left at its stock speed settings for a bit.
I have come here because "a bit" is not forever. In fact it is likely only until the start of Summer or even earlier. Also, because trying to post a 300a "celery" at 450 way-back-when does not provide me with enough knowledge to get this whole project done in an optimal manner, I need some input from those with more knowledge and experience. Thanks go out to Chris Taylor for the fact that I feel the need to OC for the first time, by the way.
The Lowdown (not the CliffsNotes
So, for my project, I already have an E6600 retail box CPU, an "OCZ 2 GB PC2-8500 Dual Channel, Platinum XTC, NVIDIA SLI-Ready Edition" RAM kit, and a PNY 7950GT 512MB video card on the way at the moment. The CPU might even show up today.
Anyway, this will all have to go into an Intel DG965WH overclocking nightmare until I am able to pick up an enthusiast board. I would think that will happen around the start of Summer.
Also, by the time I have the enthusiast board I will be running a water cooling loop for both the CPU and my video card. I have everything already, which includes a MAZE4 CPU waterblock, a MAZE5 GPU waterblock, a dual 120mm radiator, and a small AC pump. I need to get a MAZE4 Lucite top that will work on a 775 based CPU, but otherwise it is already complete.
Based on the Core 2 Duo overclocking database I found in a thread in the CPU forum here, I have set a 3.6GHz CPU OC with a 4-digit RAM speed as a long-term goal for my little project. Regardless of my goal, I am interested in making the right enthusiast MB selection to ensure I can get the best possible outcome (based on the actual OC capabilities of the CPU and RAM I receive). I was thinking eVGA 680i, but I'm not sure. To a lesser extent I am also interested in the ease of the OC experience for the board I select. I really want three x16 PCIe slots, too.
I can say I have a solid understanding of basic computer platform details, like the need for multipliers in the various interfaces among the CPU/NorthBridge RAM/NorthBridge, which busses are double vs quad pumped, and the realistic effects of changing RAM timings. I am an overall tech junkie (good for those of us in the IT industry, right?), and tend to read about these things, just not necessarily as they evolve. I am usually just a bit behind the latest-and-greatest on the tech curve for platform details.
Also, and possibly related, I am seeing references in threads around here that I don't understand. Like, for instance "800strap" in reference to FSB. Is that the same as saying "800 FSB", or is their a conceptual difference? There are others that I just don't understand the realistic effects of, such as internal motherboard latencies. Also, where can you get info such as how effectively different boards hide the little things like internal latencies so you can get the best possible OC outcome?
I do not like not understanding something I am interested in. I have only been interested in overclocking for the last couple days (since seeing Supreme Commander on my roommate's Alienware), but even though I have seen oodles of "overclocking guides", it has been impossible to find in-depth enough coverage to get explanations of just the OC minutiae I have already mentioned. I really like reading, and detail is a good thing.
Not everyone agrees, apparently.
I guess my specific questions for the people here are:
1. Does my goal seem reasonable?
2. Based on the WC loop/CPU/RAM I have already selected, and excluding current unknowns like silicon quality/yield issues, what are the remaining issues that will determine my level of success? I am thinking they are all affected by motherboard selection, but I don't really know and that's why I'm asking.
3. Any suggested reading for some coverage of "OC minutiae"? My preference is too find information that covers the details of question 2, and also sources for how different boards stack up on relevant issues.
4. Is their an issue with the RAM I ordered that is contributing to the fact that I do not see it in the entries in the Core 2 Duo overclocking database I found in the CPU forum? Other than cost, that is.
I really appreciate any help you guys can toss my way to improve the quality of my newly started, ongoing overclocking education. I have searched and read stickies, I promise.
If I missed anything in that regard, please just point me in the right direction.
