Converting over to laptop, needing storage advice
BrianPeach
I've got about 160gigs of media I would like to convert onto an external hard drive for my laptop so I can part out my desktop PC. How would I go about doing this? Who makes the fastest most reliable 1TB external HDD?
Depends on the interface, eSata will be faster than USB 2.0, FW800 will be fastest.
Depends on the interface, eSata will be fastest, then FW800, then FW400, then USB 2.0
Fixed
Also, the fastest, most reliable is going to be buying an internal one and putting it in a good enclosure yourself.
Everyone's going to have a different answer as to what's the most reliable, but any major brand external drive would be fine. I'd shop around to find the best deal on the capacity you want. I'm not sure if laptops are including eSATA ports now or not, but it's certainly something to look into.
I used to build desktop computers but stopped about 2 years ago. This new stuff confuses the hell out of me now hah. Please explain what FW800/eSATA is and how I can implement that into a new laptop. OS is Vista 32 bit.
The laptop itself is a Toshiba Satellite X205-S9359
eSATA = just external SATA drive, google FTW. does the laptop have to have an eSATA port as well or what would be required for that?
eSata is external sata. Most external enclosures have eSata/USB. So technically when you hook up to eSata it will be just like plugging into an internal sata port.
FW is firewire, which is pretty fast. Personally Ive never used it and have stuck to USB.
If your looking for fast speeds on a laptop to external, USB/Firewire will be the way to go. And like someone said build your own external drive.
What's the advantage of building my own external drive vs simply buying a USB 2.0 1TB?
You may be able to find the internal drive and a USB enclosure cheaper than buying an external drive. It all depends on what sales you find, as to which one is cheaper.
Ah, understood. Recommendations?
Checked out the laptop and there's HDMI and USB 2.0 ports, no eSATA unfortunately so that limits what I can do.
Same as building your own 3.5" external....Warranty. Most pre-built externals have a one year warranty. Roll 'ur own, and you can buy a 2.5" (laptop size drive) with a 5 yr. warranty. 2.5" drives also come in two flavors (IDE and SATA), and three speeds (4800, 5200, and 7200). Remember to match the flavor (IDE or SATA) of your drive to the case.
About the only differences in 2.5" cases is the chipset. I'd look for a case that includes a quality Prolific PL-2507C or Genesis GL811E chipset.
