Conundrum (right section?)
notarat
I have the following drives:
(3) 1TB Western Digital SATA 3 Caviar Black Drives
(2) 1TB Western Digital SATA 6 Caviar Black Drives
(2)2TB Western Digital SATA 3 Caviar Green Drives
I’m trying to decide the optimum layout of them in my new system (If I do give into the upgrade itch and get an Asus P8P67 Deluxe + 2600K)
I see the following configurations as possibilities:
1. Slice out the fast part of ALL of the 1TB Drives using my Intel Matrix RAID setup connected to SATA 3 and use the rest of the space for Mirrored RAID + Use the 2TB Drives as data dumps
2. Slice out the fast part of the two 1TB SATA 6 drives on the SATA 6 controller for RAID 0 & use the rest as mirrored RAID & Slice out the fast part of the three 1TB SATA 3 drives as RAID 0 & use the rest of those drives as Mirrored RAID + Use the 2TB Drives as data dumps
3. Each drive connected normally (no matrix raid) and create a dynamic (software) RAID setup of some sort within Windows 7 (not really an attractive option)
4. JBOD with 1 partition FTMFW (j/k)
I'm totally option to suggestions at this point as this is just a "what-if" scenario. If you have a different config, please state why you would choose a particular configuration,
You could RAID10 4 of the Caviar Blacks (at SATA2 speeds), then have the Greens for random storage.. or something. There's a million things you could do here :D
[LYL]Homer;1036694833 said:
SSD for OS. Rest of the drives just as non-raid storage.
/zing!
+1
OP, you're making a simple process way too complicated.
Remember the KISS principle. ;)
