Control - Black colours until restart graphic options
Status
Not open for further replies.
mgty23
Hi. Never had that issue of few months of gamepay.
Game Control.Today first time happened.I left game running ,standing charecter in the same place, when i back after 2 hours , all screen covered by black colour,black colour covered game elements. Just all was in black colours ( black textures ),signal on monitor was on of course.
It was possible go to main menu.
Changing resolution to other and back again to previously resolution in game menu,fixed that.Did somebody had that issue when black colour covered the screen?
PC2080 Ti Wateforce Xtreme , stock no oc
9700K stock
Windows 10 1909
Also never happened in other games.
It was hardware issue or game?
RazorWind
This is most likely just a bug in the game, like we told you before, and the time before that, and the time before that. The core of the problem is that you insist on leaving games running, unattended, for hours a time. Stop doing that.
On a technical level, the problem is that the games are buggy. On a practical level, the problem is that the games aren't meant to be used this way, but you insist on doing it for some reason.
mgty23
Oki thank you RazorWind :)So no reason to worry?Happened once.
Status
