- Oct 29, 2000
Hey all,
What do you use for this?
My most recent build (running ESXi 5.1) does not have on board video. I forgot about this until building the system, and dug around in my old boxes and found an old 3DFX Voodoo 3 2000 PCI, which I used and currently have installed.
The heatsink on it gets pretty hot though, so I presume it's using more power than I had anticipated.
What do you guys use in these situations, where 3D (or even 2d) performance is not really needed, just text console, and minimum power use is desired?
I was thinking maybe an old as dirt PCI VESA card would do it, like an old 2MB PCI Matrox Millenium or something.
Seeing that those things don't even have heatsinks, they can't use that much power, and ought to be dirt cheap right?
Any thoughts or ideas?
