JSF35rhino said:if your not overclocking it's an open ended question . there are some good MB's from $55 to $300. it depends on what you require--- ie sli-crossfire , what type of ram your going to use--how many satas, how many patas--ect .
the core 2 is such a good overclocker i don't see how you could not want to oc it at least a little--![]()
i like the dfi 975x for sli or crossfire and a mild oc .
the gigabyte 965p in the inexpensive s-3 , and maybe the biostar T-force 965p for big-time overclocking . although there are several MB from asus and gigabyte that oc very well in 965p . i also like the asus 965p delux but since it's expensive i haven't bought one .
on the uber low end--migration MB --i like the asrock 775 dual vista . it's an old chipset that uses the via 880pro. it's not a overclocking MB . it can use ddr 1 or ddr 2 , it has 8x agp and 4x pci-e which is about equal to 8x agp . two patas and several sata 1.0's
it can overclock some --with ddr -400 i've been able to push mine as high as 334fsb. i saw on a thread somewhere a few have pushed it to 340fsb which is as high as it will go. but i don't think anything over 320 is of much use. mine runs best around 317fsb with a 6400. but for $55 it's a flexable mb and is nearly as fast as the intels running ddr 2 when running the same cpu speeds. when the e-4300 core 2 comes out with the 9x multi for $160 you'll be able to build a nice core 2 computer--saving your ddr 400 from your last build for like $220 ish total --9x overclocked to 300fsb = a core 2 running 2700mhz--not bad for the $$$
a 6400 will oc pretty good on the asrock . lots of them are being built with an eye to--when high speed ddr2 800-900-1000mhz-get's cheap i'll toss the via 880p and then get a 965p . which ain't a bad idea in the long run either.
coolrunnings said:I'd suggest a PC Power and Cooling power supply. The 610watt Silencer can be had for about $160 and it's an incredible PSU for the money in my view. The P180 is an excellent choice. I've had two of them and though they are a pain for cable routing, it's worth it for the quiet computer with good airflow. May I ask why you're going with 4gb of RAM? XP doesn't really take advantage of more than 3gb unless you're running a 64 bit OS. Nice choice on the hard drives. I'm running a pair of 250gb 7200.10s in my main box and 5 320gb 7200.10s in my server and I gotta admit, these are GREAT bang for your buck drives. What type of work are you planning to do with your machine?
pro956 said:HEATSINK: ???
THERMAL: ???
MEMORY: 2gb of
Vid Card: probably something low-end that will support 2560x1600 and dual dvi-d maybe a (Radeon x1600 pro 512mb pci-e)
Gigabit-Ethernet: ???
And yes, I will overclock... and report my results!
pro956 said:Latest:
CASE: Antec Performance I P180
PSU: Silverstone st60f
CPU: E6400
HEATSINK: Scythe Ninja
THERMAL: Arctic 5
MOBO: ASUS P5B Deluxe
MEMORY: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
HDs: 2 Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drives
Can someone link me to a good deal on a video card that will support 2560x1600???
NO REBATES...
price range will probably be $100-$200 on the video card... more concerned with the deal than the best I can get for $200...
I guess I will need a DVD-RW as well, any of those cheap 30 some dollar deals going on?
Thanks guys!
chrisf6969 said:If you're not overclocking ANY motherboard will do. Go buy a $50 ECS pos.
Dan_D said:This is some of the worst advice I've ever seen on this forum. Not just any motherboard will do. There is a huge difference from one brand to the next when it comes to quality. There are many motherboards that are hard to make work at stock speeds, and not all chipsets used to create the $50 motherboards are created equal. Not to mention ram compatibility, and general compatibility with hardware could be a problem as well.
pro956 said:Okay thanks everyone,
I've ordered everything BUT the video card.
And the aftermarket fan/heatsink (was going to tap the ninja onto my newegg order but it was OofS)
Any links to decent non rebate deals to a vid card?
Thanks again.
coolrunnings said:I've heard some ok things about Silverstone... Haven't personally used one though. I'm quite curious how the cables will reach though in that P180. Let me know eh?
loxety said:Why not look in the for sale section.
BlastRadius said:In my opinion the board with the best feature set is the Asus P5W DH Deluxe.
Somebody argue that point... at least I got your thread going![]()
pro956 said:http://www.chiefvalue.com/product/productdetails.aspx?item=14-102-033
is the video card I picked up today.
as long as it works with my dell 3007wfp i will be happy.
it supports 2560x1600.
and i'm 99% sure it supports dual link dvi-d
can anyone clarify this?
Thanks again everyone!
