Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an Exos, and it's been through socket A, 478, and 939, all three seperate adapters. As far as ease of use, Koolance does a wonderful job of making each adapter work very well with whichever platform it's being used on, easy to install, screw it down until it clicks.
As for performance and conroe, I couldn't tell you, but if I were able to build a conroe system like I would love to, I wouldn't think twice about it.
If I was planning on serious overclocking, however, I wouldn't use it unless I got a PC Power and Cooling 1000 Watt PSU. Right now I'm doing some moderate overclocking in a system with 8 hard drives and a 7800GTX, but if I was doing SLI or trying to hit some speed records, I'd want to power the water pump seperately from the system with my 550W PSU just to be sure I had what I needed.
