Dr1zztth3hunt3r
- Aug 1, 2006
Hello,
I have been searching these forums for the last 2 hours and have found so many conflicting reports about which boards support the 7950 and which don't, anyone running a conroe motherboard and the 7950 would you please tell me if you are:
-using hacked or official drivers and which ones
-if both your GPU cores or only one are supported
-what Mobo you are using
-any major issues you have had
thank you everyone in advance
