Connector needs to dictate purchase
sabregen
To all that have not seen my recent spending spree, and pending new build....I require your assistance in picking a new power supply for this build. I have several as of now, and if you have any interested in trades, please let me know. The ones that I have can/will work, but not without power dongles and all that mess. Here's what I'm looking for:
~ 600w. Doesn't need to be much more than this
6x SATA power
6x 4pin molex
1x floppy power
at least 3x pci-e 6pin (would prefer 6+2 configuration)
24pin main power
8pin EPS 12v
4pin P4 12v power
must be sleeved leads
leads must be at least 20" to first connector. the longer, the better
prefer modular
crossifre or sli certified
80+ certified
under $150
does such a beast exist?
always good to have options. I should have specified though, that i hate MIRs, so the first one is likely out of the running. Last year I had (for a brief period of time), an Antec TruePower Quattro 1kW. I hated that you could not plug in all of the cables. I tihnk I'll stay away from the Antec modular. You have no idea how disappointed I was to find out that although I had plans for all of the connectors listed on the site (at the time), no where was it mentioned that you can't use them all.
It should be noted that I own many Antec PSUs, and do not hold a grudge, but I can't support crap marketing like that.
always good to have options. I should have specified though, that i hate MIRs, so the first one is likely out of the running. .
Actually, the Corsair 620HX can be found at buy.com and zipzoomfly.com for under $150 before any sort of rebate. However, it only has two PCI-E 6+2 connectors, just one short of your requirement.
Though a bit puzzling: If you need all those connectors, that means you really don't need a modular PSU since you are planning to use all those connectors. Kind of makes the whole point of getting a modular PSU a bit moot. Oh well.
The BFG I run has all those requirements except the modularity. Oh, how I wish it were modular.
ah yes, lest you forget, the initial installation and cabe runs/hiding in the chassis. This is why I prefer modular, for initial setup, not for later modification.
