ive got a Samsung LE26R87BDX HDTV, and my laptop has DVI out, so ive bought a
DVI-HDMI cable, and ive adjusted the resolution so that its 1360x768 ( same as my display) and ive adjusted the refresh rate to the same as my set (60Hz)
but i get a black border around the picture! and i can only adjust the picture size from 16:9 to 4:3, because the other modes are greyed out
has anyone had the same sort of problem using a HDTV?
thanks
thanks
