Hello,
I'm a little behind because my last upgrade was 3 years ago. I will have:
E6600
GA965P-DS3
Antec NeoHE 500W
So, the power supply has so many different connectors. I'm reading MB manual ant it says ATX_12V is only for cpu. But then it says:
"If you use a 24-pin ATX power supply, please remove the small cover on the power connector on the motherboard before plugging in the power cord"
This is confusing. Do i need to use both connectors? Or if i use ATX_12V, then i won't need 24-pin? Also, the PSU has 8-pin connector, but i have no idea what is it for. Please, give me some advices before i did something wrong. Thanks.
E6600
GA965P-DS3
Antec NeoHE 500W
