luckylinux
- Mar 19, 2012
Hello. This is my first post here and I hope somebody can actually give me some tips.
I got a very nice deal (1x 650$) for two Supermicro SC847E16-R1400UB.
However this is a UIO case with PCI/e mounting parallel to the motherboard.
I contacted Supermicro's technical support in Europe and got very fast and (what I think to be) very good answers.
Basically for using these cases as JBOD enclosures I should buy:
- 1x controller with external SAS port (AOC-SAS2LP-H4iR) or other validated model (~ 550$)
- 1x CSE-PTJBOD-CB2 power board (~ 70$)
- 1x CBL-0167L-LP internal to external SAS cable (~ 70$)
- 1x CBL-0166L external SAS cable to connect JBOD to main server external SAS port (~ 60$)
However a few things are holding me back.
They say
And
That seems a bit scary as I'll be using this at home. Even though I'll not use all the 36 HDD bays from the start, for that price it was really a deal.
Here is the list of supported SAS/SATA controllers.
I'd like to hear your opinions on the matter, i.e. if you know if the WD green, WD black, Samsung's 2TB (F4?) or Hitachi's mainstream HDD should work.
I ask this because it seems it would be sort of unsupported. The adaptec 5445 (for the same price) allows this?
Operating system will be Solaris 11 with napp-it, unless somebody here will make me change my mind and go the FreeBSD 9.0 route. I'd like to use encryption though and therefore should use GELI. Using ZFS as filesystem. Storage include data and media as well, as well as some NFS/SMB moutings.
"Real" server might also host a bunch of virtual machine's DATA (but not run them) therefore I might need SSDs. Don't know if I can do both SAN and NAS with Solaris 11, but surely NAS will do. This server is (already
) in a Fractal Design Define XL case (big and well ventilated) with up to 10HDDs drive capacity (that will not be used). Maybe a good idea might be to use a drive enclosure that allow hot-swap (like this) for just the SSDs. Do you know any for 2.5'' inside a 5.25'' slot (up to 4x5.25'' and as many 2.5'' as possible). I found this and it seems to support SATA 6G speeds (as the site says) but my retailer says it doesn't. Do you know any alternatives?
CPU is AMD FX-6100 with 16GB RAM ecc-unbuffered and a highly power efficient Corsair AX750 (overkill, I know). Not planning on using dedupplication since this will increase a lot the RAM requirements. For SSD I might use a standard 4-port Adaptec Controller for arount 100$ (anyway SSDs want speed, so 2x4port is better than 1x8 port
Thank you very much.
I hope this post was not too long to read and explains the situation in detail.
They say
You can use SATA harddrives but then it is imperative to use validated SATA harddrives as ONLY these models are compatible
And
The chassis 847E (E = Expander backplane) includes the expander chip in the backplane
The compatibility depends on
- harddrive supporting expander backplane latency etc
- And the controller supporting expander backplane
- And combination of the 3 items (expander/HDD/Controller)
The WD2002FYPS drives can be used although we cannot guarantee compatibility because these drives are not validated even if the 1TB models are
