Myth Back-end + NAS (already own the parts; cept 3x 1/1.5TB HDD)
This machine will do all video capturing/transcoding.
It will also be the Backup Server/NAS....
1x Old Lian-Li midi-Tower or Chen Mei FT
1x Gigabyte 8600GTS .................................... [take transcoding load off CPU w/VDPAU or is this def. not doable?]
1x Hauppauge HVR-2200 .................................. [may eventually add a 2nd one]
1x GA-P35-DQ6 (ATX form-factor)
1x TWIN2X4096-8500C5DF ................................. [2x2GB DDR2 1066; 4GB enough?]
1x Core2Duo (conroe) E6420 2.13Ghz ..................... [may underclock/volt slightly?]
1x Antec True Power 3.0 650W ........................... [Less wattage possible?]
Storage Sub-sys:
1x 1TB WD Black ........................................ [video capture disk, can it handle 4 simultaneous HD streams?]
1x 150GB 10k RPM Raptor ................................. [boot/system volume?]
3x 1/1.5TB 7.2k RPM HDD ....................... [For content storage & BU, may not bother w/RAID till get hw controller?]
Myth/XBMC Front-end (don't have the parts; cept where mentioned)
This will be the media player & MAME PC...
Later (6mth) I'll buy a top-end GPU that'll be swapped-in sometimes for gaming.
1x mATX H57 or Q57 mobo. ......... [make/model?]
1x Intel Core i3 530
2x DDR3 1GB ...................... [make/model?]
1x 30GB SSD or USB Flash? (already own; 4GB) + 74GB 10k RPM Raptor? (already own, for local storage)
OR
1x 1TB WD Black or Samsung F3? [innermost sectors -20GB?- for OS, outermost for local storage]
1x Xonar Essence ST (already own, PCI)
1x H6 (already own, Essence daughterboard)
1x PSU ................................ [perhaps BE PSU is best here if I intend to use strong GPU sometimes; make/model?]
1x Case ............................... [make/model?]
1x nV GT220 ....................... [only if IGP+CPU not enough; make/model?]
For the back-end I was thinking of doing a minimal Ubuntu install & only adding what is needed.
For the front-end I was thinking of starting the same way and gradually adding MythTVFE, XBMC, and maybe a lightweight DE like crunchbang etc.
Interested in peoples thoughts on what I'm missing hardware or software wise or just some general advice.
Thanks!
________
discarded:
1x 74GB 10k RPM Raptor .................................. [very old -not used much- slightly damaged connector so connection always a bit loose]
1x 4GB USB flash for OS ................................ [apparently USB flash unreliable when lots of writes involved?]
1x 80GB? make/model YTBD
Storage Sub-sys:
OR
Thanks!
________
discarded:
