Computer won't turn on at ALL
Konowl
I think it's the motherboard, not sure....
Just built a new computer, wired everything up, turned it on, worked fine. Cycled through a few POST's, booted the Hiren boot cd, worked fine. Had to go grab some system disks, turned it off went and grabbed them. Came back, computer doesn't turn on. Nothing. LED light on motherboard is lit up, but power button doesn't work neither does making manual contact on motherboard power switch with screwdriver.
ASUS M2A-VM motherboard with an AMD 3500+.
Thoughts? Is the PS done or the MB?
- Well what power supply do you have?
- Do you smell anything from the power supply?
- Try another power supply
- Try reassembling the PC outside of the case, with the motherboard on the motherboard box and start it by jumping the power pins. If it starts, than something inside the case shorting out the mobo. If it doesn't, there's a possibility that mobo is dead.
If you're paranoid enough (like I am), if you decide to assemble the PC outside the case (which is a good idea), start with only the basics, CPU, RAM & video card... and then add to it to find the culprit.
Also, if you have a voltmeter and the ability to test the P/S, that could verify that the P/S is shot.
Otherwise, as Danny Bui said, the MB might be shot.
I would try resetting your bios by clearing your CMOS and then try again. If it boots watch it and see if you can tell what happens.
I would also check your power supply and see if it needs reset. Many power supplies have a way to reset them with a breaker switch. Anyhow, I have seen many times where folks don't have a powerful enough supply for their system (especially with todays graphics cards) and when they fire it up, their power supply kicks em in the gnards.
How many watts is that power supply? How powerful of a video card are you running?
I would check your connection for your case to the motherboard and make sure your +/- is right. I've had times where they were wrong and the system would peridocially boot, but sometimes didn't. When I fixed them it was fine afterwords.
This happened to me on my most recent build. The green wire/pin on the 24-pin ATX connector wasn't making good contact and the power (either by button or by shorting) wouldn't work. I'm not saying that is the culprit in your build, but it is something worth checking. It might account for your intermittent problem.
-I've treid shorting it manually (power connector), nothing
-I've also tried it in another system, same deal, didn't work... leading me to believe it's in fact the motherboard
-it's an onboard GPU, power supply is 350 watts
-tried resetting CMOS already, didn't work
Just boggles my mind, as it was originally working fine then suddenly kaput
Just had this happen myself. I tried all of the above . I even had an extra power switch and still nothing. It was depressing! I finally gave up and bought a new board. Any chance of an RMA? I feel for ya.
WOW that sux man, I had something like this happen with an "Included in the cae" PSU. It was total Carp. It fried istelf on first powerup luckily my MB and everything else was safe. I would try to test the PSU before worrying alot about the MB although if you installed all the components into another system with different PSU and it still dod not work it spells trouble for the MB. If you did nothing to it Asus is sometimes nice about RMA but you will get a refurb board which maybe more trouble that you bargained for. Try to RMA if possible, I know I would. Better to have some hope than none at all right? :) GL
