Computer won't boot after video card upgrade
WhatTheSchmidt
Removed old drivers, booted into safe mode and used driver cleaner. Then I turned off the computer, swapped cards(8600gts -> MSI 4830). Installed new drivers, then installed net framework 3.5 because CCC wanted newer net framework. Rebooted, seemed fine, played a game for a few minutes but the fps was bad at full settings(world of warcraft). Turned off computer and now it won't reboot.
What could have gone wrong? Should I try resetting bios to reboot? I have had a stable overclock for a year and a half and don't remember all settings ><.
What should I do?
Thanks
Important thing to add..When I turn the computer on, all the fans turn on and pump, no beep that usually happens when it starts booting up, nothing displayed on monitor.
tried diff video cards, no change
tried resetting cmos with jumper reset, nothing
tried taking battery out for a few min, nothing
unplugged unnecessary things during these tries, nothing
no bootup at all, fans and pump, HDs, dvd burner power up
what else can I do? before I have to buy new expensive stuff..motherboard? cpu? corsair psu?
Try unplugging the AC cord from the back of the power supply and hit the power button on the tower to discharge it, then plug it back in and power it up.
Next, unplug all of the drives, remove all cards, RAM and reset the CMOS. Bit the power button and see if you get a single, long repeating beep. If you don't, the power supply, CPU, or PSU are bad. I would start with the PSU first, then a new motherboard. Hopefully, you won't have a bad CPU.
Try following the steps under the Basic Troubleshooting guide under the "No POST" part
Ok I didn't know such a guide existed. I will try what I can with that but I don't have any spare parts here besides pcie video cards. Also I don't know if beeps work on my computer or not. Usually I get one fast beep when booting up, that's the only beep I ever have gotten with my computer.
This is the worst thing to have to figure out...I tried searching for threads like this one but couldn't find anything.
update:
tried everything I could with what I have, followed troubleshoot with no post guide
got no where. NO BEEPS on my onboard buzzer on the p965-s dark motherboard. Jumping PSU worked fine...PSU seems fine.
with no ram or video card just mobo and power hooked up fans and pumped turned on(didn't unplug these, no reason) but no bootup, NO beeps at all
my conclusion is my motherboard is dead...is there anything else to try easy? before I have to order a new motherboard and go through all that hassle? (side question, I have 2 hard drives..with getting a new mobo will I be able to take files off my raptor and xfer to my storage drive, or do I have to format the raptor and install windows..etc?)
what a joy before my paper and 3 exams next week...followed by spring break
