Hi guys, I think I broke either the motherboard or CPU.
Here are my PC specs:
Phenom x4 965 BE
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
ASUS M4A87TD
Sapphire 6850
HAF 922 case
Corsair 650 watt PSU
Cooler Master 212 Plus
I tried to OC the 965 BE. All I did was changed the multiplier to 20 and the voltage to 1.495. After the PC restarted it never went into the BIOS again. So basically what happens now when I turn it on is that the the case fans, lights, motherboard light up but the system never goe into Windows or into BIOS, the BIOS screen never even flashes. I already tried to reset the motherboard using the pin method and also took out the battery for 30 min and it still won't post. When I turn the PC on there is no "beep" indicicating anything is wrong. I tried to start up the PC with just one stick of RAM, same thing, I even tried starting it up without any HDD, it still doesn't post.
Any idea what I should do next?
Phenom x4 965 BE
ASUS M4A87TD
Sapphire 6850
HAF 922 case
