Ok last night my computer started getting a bluescreen that says something about an error and that it's shutting down to prevent damage. at the bottom it says physical memory dump and then it just restarts.
and then random artifacts started showing up on the screen when i log into windows, like blue lines across the screen and little dots at random places. i was still getting the bluescreen everytime i log into windows for a few mins.
next, the artifacts started showing during post as well.
i turned off the computer, waited a few hours and turn it back on. everything was fine for about 2 hours. I restarted, ran memtest, for a couple of hours, it passed 100%. i also have NVIDIA monitor monitoring my GPU temp, at around 58C which should be normal.
this morning, i turned it on, everything was fine for about 15 mins, then the monitor just randomly went black. i turned it off and went to work.
Any idea what is going on with my computer? I figured it's either the memory or the video card? Any help would be great!
Computer info:
Intel Core 2 Duo E6750 @ 3.4GHz
GIGABYTE P35-DS3R Rev.1
3GB Crucial Ballistix
eVGA GeForce 8800 GTS 640MB
Corsair 620hx
Windows 7 Ultimate
Computer info:
Corsair 620hx
Windows 7 Ultimate
