Computer thinks it is overheating
cjstev
Help!
I have an hp pavillion a430n. AMD Athlon xp 3800 2.4 GHz. I can turn it on and Windows xp home will load but then the computer will freeze (screen stays on), the fans turn on full speed and the power button blinks. It seems the computer thinks it is overheating. I can get Windows to shut down by pressing the power button. After the computer turns off the power light continues to blink and the fans stay on high speed. After trying to turn it on again sometimes it will boot up other times it will turn on with the fans at high speed and the power light blinking.
I turned it on and went into BIOS hardware monitor. While watching the cpu temp in BIOS, I discovered that when I physically bumped the computer the fans went high speed again. BIOS monitor reported cpu fan speeds of zero and my cpu temp jumped 5 degrees Celcius. Sometimes the computer will do this without being bumped. It seems like something is loose but I do not know what. Computer will freeze like this from BIOS and Windows. I also reseated all my fan connections but that did not help either.
The computer will run only a couple of minutes (or until I bump it) at the most before this happens.
I tried a different PSU and same thing. I bought a new cpu (used, untested, but guaranteed refund if it does not work) and that did not fix it. I am beginning to think it could be the MOBO (ASUS A7N8X-LA Focus). I know that the MOBO has hardware monitoring. Could that be messed up somehow to cause these symptoms. I would like some help before I spend more money.
Thanks.
sounds like a bios issue, you can try flashing it. If you replced the cpu im pretty sure the heatsink is sitting right. Either way you will probably ahve issues with that board just replace it, ive never seen a cpu go bad, yet.
Well, what are your cpu temps when this is happening ?
Forget the case fans, its the cpu heatsink/fan that needs close watching, but if it is spinning up full speed too and the HS and thermal compound is properly installed I dont have a clue and tend to agree with you on the motherboard needing replacing.
