Computer stuck in endless reboot (details inside)
bananaRAM
So my computer is stuck in an endless reboot, and my guess is it has something to do with the boot record, but here goes anyways...
Computer boots up, I get the mobo/BIOS splash screen, see the quick run of all stuff at the prompt (verifying DMI Pool Data), then I get a quick splash of the Windows loading screen and then the screen pops up "Windows was not shut down properly... yadda yadda yadda, Safe Mode, Command Prompt, Last known working, and boot normally.
Here is where it gets tricky... there is obviously power going to the keyboard as the lights are on, but the keyboard does not work at this screen. So I let the countdown go and it tries to boot again, repeat process above. I can get into the BIOS and the keyboard works fine. Everything from the BIOS looks ok, but I'm not a guru with all that stuff. But I choose to boot from the CD-ROM with the Windows XP (SP2) disc in and choose recovery console.
I ran CHKDSK /R and when it was finished it said something along the lines that it fixed one or more files. So I type EXIT and still endless rebooting.
(Note, prior to the endless rebooting, when I tried to power on the computer, the computer sounded like it was booting normally, might have been stuck in the loop as well, I don't know, but it never triggered the monitor to come out of sleep/power save mode. A few tries later, and I am where I am above).
Does this sound like a boot issue? I really don't want to wipe the HD clean with a fresh install so what I'll end up doing if I can't fix it is buy another HD and install fresh on that, slave the old HD, back up the data etc etc. But if I can fix the booting issue, that would be great.
I've never used the FIXBOOT and FIXMBR commands, is that a logical next step? Any help would be greatly appreciated. Thanks!
Crap, completely forgot PC specs:
MSI mobo (forget which off hand)
AMD 3700+ (single core)
Sapphire Radeon 800XL 512M
WD Raptor 74G 10k rpm drive
Creative X-Fi Sound
2G (1G x2) Crucial Ram
Windows XP w/ SP2 (but was upgraded to SP3 weeks/months ago)
PC was built roughly in October of 2005
[Testing the RAM]
Download Memtest+ v2.10 or whatever the latest version is, unzip it, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Let Memtest+ run for at least three hours on each stick of RAM separately as well as test the RAM all together. Go for a full 24 hours if you want to be completely sure that the RAM is not a problem. If you start seeing errors, than your RAM is defective or you have incorrect settings for the RAM.
[Testing the Hard drive]
Download the CD image of Hitachi Drive Fitness Test, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Test the hard drive and see if any problems are found. DFT will run on most manufacturers' hard drives. Alternatively, you can use Seagate's SeaTools for DOS to test a Seagate or Maxtor drive. For a Western Digital drive, you could use Data Lifeguard Tools for DOS to test a Western Digital drive.
If those tests pass, then boot with the XP CD. Proceed as if you were going to install XP. After agreeing to the EULA, choose the same partition with the existing XP installation. Setup should detect the old installation and offer to repair it by pressing the "R" key. Go ahead and hit R to repair the existing installation. If setup does not detect the old installation, then you either chose the wrong partition, or the installation is FUBAR and you'll have to reinstall anyhow.
