So I left my computer on and went outside for about 10 minutes, when I came back the computer had shut off and wouldn't turn on again until I had reset the CMOS. After that it boots normally until it encounters the Welcome screen on Win7, right when its about to pass it everything stops working and the screen looses the signal. This also happens if I try to boot using a Fedora Live CD, right after the loading is complete everything stops working and only the fans keep spinning.
Booting into safe mode is fine and everything works there, I tried uninstalling the video card driver but had no luck with that. My computer was running OCed when this happened but I had stress tested it and it was stable and temps were fine. I also ran Prime95 for a while in Safe Mode at stock settings and everything worked fine. My 700W Psu stopped working after a few start ups so it might be dead.
I have tried using another PSU although it was only 430W and the same thing happens, Im beginning to suspect the MB is at fault but I'd like to hear your input either way.
So if you have any ideas to what I could try they would be much appreciated.
My computer consists of:
AMD Phenom II 955 BE
MSI 770-C45 Motherboard
Ati Radeon HD 5870 1GB
4GB G.Skill 10600 DDR3
1x IDE HDD and 3x Sata HDD
700W Tagan BZ Series PSU
Edit:
Ok so now i got through that screen and into windows using another HDD with installed Win7 but after running Win for about 30secs the same thing happens.. I have no idea what could be failing :/
Edit:
