computer self-restarts
Likwid_Nitrogen
My computer self-restarts about 3 seconds after power down everytime unless I throw the switch on the power supply. I only have to turn off the power supply during that one 3 second moment; I can turn it back on immediately after without the computer turning on. This only happens after a normal soft off, and not if I hard off the system (holding the power button 5 seconds or whatever). Also happens if the system tries going into suspend mode, putting it into a zombie-like on-but-won't-wake-up state.
All wake-on-(x) options are off in bios. Problem persisted before and after a new case build. In the old case build, I would hear an audible click from somewhere at the restart moment 3 seconds after power off, whether or not I had turned the power supply off.
Any ideas?
Please list out the specs for both builds. Also, are you using any part from your old build in the new build?
Posted via [H] Mobile Device
Ah yes. Same components in both builds, just a new case.
Asus PQ5 SE/R mobo
Core 2 duo E8500
2gb patriot
Asus TOP gf260
500gb Samsung Spinpoint F1, 1tb Samsung Spinpoint F1, 320gb WD
dual boot XP / Win7 (happens either way)
all currently shoved in an HTPC case.
no overclocking
What power supply?
Be sure to hit up the stickied basic troubleshooting guide.
