Computer issue - Motherboard? PSU? Help?
BlackHawk22
Hey - I am having a computer issue somebody here might be able to help me with. So let me give you the story:
I was sitting at my computer, the screen went wierd where it showed a pattern of RGB triangles:
= = <--- Like that, but all over the screen ( about that same size too..)
And the computer was frozen, pressing the reset but to no avail, I flipped off the power and turned it back on - it booted up, no further issues. That was yesterday. Today the same thing happened, but when I went to turn off the power, my foot just hardly touched the side of the case (Honestly, not hard enough to cause a problem, or even hard enough to harm a fly) and the screen went black, LED fans went off - no noise, no nothing... Except on my motherboard (p5n32-SLI Deluxe) there was a green LED on that indicated power to the motherbaord. I turned it on, still nothing - I unplugged the cord, nothing - I went and opened it up, tryed unplugging everything, except for one LED fan. Still nothing. I would assume my power supply is screwed up, if it werent for my motherboards LED going on when the plug was in. Whats up with this? What could case such an issue? Only thing I could think of was that the 12v rails in the PSU are fried, but the motherboard plugs still work - or the processor doesnt work (but that doesnt explain why the fan doesn't go on...). I honestly don't know what I am talking about here with PSU's, so please help me.
System:
Ultra X-connect 500W PSU
Asus P5N32-SLi Deluxe
Intel Pentium D 820 (untill quad-core :) (Penium D 805 on the way in the mail ( OC's to 4.1Ghz on air))
w/Scythe Ninja + 120mm fan and Arctic Silver 5
EVGA 7900GT KO Superclocked
w/Arctic silver 5
Airlink101 SuperG Wireless Card
WD 120GB SATA-I 7200rpm 8mb Cache HD
1GB Kit - Kingston DDR2 - 533Mhz (Better memory in the mail!)
Come on guys.. I know it looks confusing and almost as if you have homework by reading it - but I could really use the help.
Make sure Ninja is seated well. I had similiar problem and just happened to check my processor fan mounting pins and one had popped loose. Reapplied compound and reset fan, no problem since.
I had something like that happen once on a build I did. It did turn out to be the power supply.
I talked to a power supply tech when I had to RMA a PS a while back and he told me that even though the power supply may be faulty it is still possible for the leds on the motherboard to light up indicating PS is supply power to the board.
Do you have another power supply you can test with? If you are getting no POST beeps or no display at all i can almost gaurantee that it is a power issue. Ironically enough we had 2 power supplies in one system that were flaky, the user had the computer on the floor and with even a slight bump the system would reboot.....swapped out the power supply 2 times (one was an original antec and the next was a thermaltake) and i believe we have finally resolved the problem.
I would agree that it sounds like a psu problem. They do make some pretty cheep psu testers these days. I saw one in Fry's the other day for like $12.
BlackHawk22 said:
Thanks for the speculation! Helps alot!
Not sure how to read the tone of your response - hopefully it's not sarcasm. :(
I agree that it sounds like a power supply problem. The green led on asus mobos just indicates that you're getting some juice, but not necessarily enough to run your pc. Notice how it's on with just your ps connected, without hitting the ps button on your pc?
I'd try another ps. Ultra's aren't known for quality stuff. FSP, Sparkle make some solid, inexpensive power supplies.
Well I tried swapping with a old 350w PSU and it did the same thing... Coincidence?
BTW - will a power supply be able to make a fan run, with nothing else attached to it, or does it need to be hooked up to a mobo?
It doesnt have to be hooked to a mobo but you will need a jumper wire to connect 2 pins in the connecter that would connect to the mobo.
im looking at which pins to connect as i dont remember right off hand
that old 12 v might not have enought amps on the 12v to do the job with the nf4 and the 805 need lots of amps on the 12v rails. try something arouns 450w to 550w with at least a full 18amps on the 12v rail if it has duals and at least 30amp if it's a single rail unit .
those ultra x units are of doubious quality --i got one for free with a TD case and it toasted some stuff after a couple weeks . supposedly the infinitys are better--but the tp-2 500w is only $69--so why skimp there ?
the only other thing i can think of is the nf4's sometimes have problems booting because of bios issues --you might try clear coms or remove the battery --and lastly it could be a ram problem --try removing or swapping ram slots and or booting with one stick .
sometimes after a bios flash or a memory swap a nf mb will tune the mem timings to the wrong setting and cause what looks like a dead mb . and you could just havea dead bios chip -- i had a number of dfi-that had to be rma'ed because the bios chips died--
trouble shooting a computer is like working on an old car--you start out swapping the easy cheap stuff and by process of elimanation work your way up the chain--good luck with it !! :cool:
That sounds like an awesome bit of help... - If I hade a DFI NF4
Please re-read my post. Its a P5N32-SLi Deluxe...
