Computer Help
Jon/xpm
Hello,
Can you please provide some help ASAP
The current issue with the computer is that the monitor will sometimes have no picture at all and the monitor blink will blink on and off.
I have been able to get the picture back when I turned off the monitor and restart the PC.
Also, I noticed when I unplug the DVI cable from the back of the monitor the blinking light on the monitor goes away. With the DVI cable being unplugged from the computer monitor, i still get message "no signal" message on the monitor
Could this be an issue with the monitor, video card or something else?
Thanks
Jon
hit up the Stickied Troubleshooting Guide on what to do when the PC doesn't POST.
... Also, I noticed when I unplug the DVI cable from the back of the monitor the blinking light on the monitor goes away. With the DVI cable being unplugged from the computer monitor, i still get message "no signal" message on the monitor ...
how would it get a signal if you unplugged the cable? :confused:
Does the system POST?
