For some time my computer has frozen at random times and at some predictable times. I have never been able to identify the issue. When sending a large file (over 2 or 3 gb) over LAN the computer will freeze up completely and require a hard reset. I recently encountered the same problem when trying to sync my ipod to an 80gb library.Transferring smaller files over LAN or USBseems to be fine. Occasionally the computer will also freeze whilst gaming. I have taken the following steps to try and isolate/solve the problem.
Re-installed windows, and again on a different hard drive, and again with a different version of windows. Both versions have worked flawlessly with other computers.
Checked all drivers have been updated.
Run Memtest for ~25 passes with zero faults, and then tested with alternative memory in different slots for good measure.
Replaced the video card to one that worked perfectly in another system.
Changed the case the system is installed in, I also used a different power supply.
Ran Intel burn test on the CPU, again with zero errors.
Concluding that the issue was the motherboard the evga rep agreed once I detailed the problem, I RMA'd the motherboard. I received back a brand new board, up until this the random freezing had been more frequent often happening within an hour of the previous lock up. Since I got a replacement board the random freezes are rare, but the system still has a 100% failure rate when transferring large files over LAN. Over the past year I have tried to Google extensively for solutions but have never come up with anything. I have listed my system spec below. Thank you in advanced for any assistance.
Intel core i5 750
Evga p55 SLI
2*2gb Corsair Dominator ram
Seasonic x-760 PSU
AMD 5750 1GB
Intel core i5 750
Evga p55 SLI
Seasonic x-760 PSU
AMD 5750 1GB
