computer freeze/crash -where to get report
bluesmap
when my computer freezes or crashes once i boot back up successfully where can i go to get a log and find out what happened? is a log kept? how can i go about determining what is causing my freezes and crashes?
this is a new build so im not sure whats wrong
Event viewer would be a good place to start. It won't give you any clues about freezes (that require a restart) though.
no idea what the hell this means:
On Sat 1/14/2012 6:30:17 PM GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: Unknown (0x00000000)
Bugcheck code: 0x7F (0x8, 0x80050031, 0x406F8, 0xFFFFF80002EAD3B9)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown UNEXPECTED_KERNEL_MODE_TRAP
