limitedaccess
- May 10, 2010
Does anyone know of any computer cases designed so that the motherboard faces to the right of the case (looking at the front of the case) instead of the left?
Is BTX the only option? Wondering about the implications due the wider selection of ATX parts, and possible future upgrades/resale.
The thread has already been moved.Edit: Most cases aligned the way you are imagining simply have the mobo turned upside down, so the ports point out the back. Consider PM'ing a mod to move this thread to the "Cases & Case Modding" forum to get more suggestions.
The Lian Li's I can find
So I looked at the suggestions, and the Silverstone's just wow. I could find RV02s for ~$160 locally (not too expensive for a case), and that design really seems to make sense thermally as well. The 180mm fan version was of interest to me, since it seems it is possible to buy replacements. Sadly both the RV and FT are too long, since I need to be able to perch it on a "shelf" that is 50cm in length with a back wall (can stick out a bit from the front, not the back).
That Lian li V1000B is hard to find here, I found a place without stock listing it at ~$260, while not really out of what my budget would be, is quite a bit for a case. I also have some concerns about how it would handle thermals for a video card, since it seems it would have to intake hot air downwards (with current gpu cooling solutions). I'm also somewhat puzzled about why Lian Li still uses 80mm fans (this is something that I've noticed for years now).
Might need need to go with a micro-ATX SFF build just for a change of things then it seems. Will see how things turn out, not desperately in a rush for a new build.
