Computer Build Help
w0lf42
Gaming. Some Web Development. Web Browsing. Watching Movies. Listening to Music.
$850. Tax and Shipping included
3) Where do you live?
Washington State
Motherboard, CPU, RAM, Video Card
Kingston 128GB SSD
Silverstone 850Watt PS ST85F-P
Western Digital 160GB Cavier
Antec Sonota Case (will be replacing in the next 6 months).
6) Will you be overclocking?
Depends if it's worth the risk and how difficult it is.
22" Samsung
2 Weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, SATA 6Gb/s
Windows 7 Professional 64bit
Word on the street is Sandy Bridge is the way to go.
I really want to put 16GB of RAM in my system. The reason is, admittedly, dumb - my first system had 16MB. I was hoping to use a RAM Drive.
I am willing to pay a small premium for aesthetics. Not only will I have a window, but I'm in the design stage to build my own case.
Here's a starting point:
ASUS SABERTOOTH P67
Intel Core i5-2500K Sandy Bridge 3.3G
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
I can't recommeThat Sonata case is gonna severely limit your GPU choices as well as seriously affect your cooling capability. You sure you can't replace the case right now?
Did you choose that Sabertooth based on aesthetics? According to your answer to question 9, it does not look like you need that Sabertooth mobo. Even if you're buying based on aesthetics, that's ~$125 just for aesthetics when the mobo in this combo link will meet your needs:
$330 - Intel Core i5 2500K + Gigabyte GA-Z68A-D3H-B3 Intel Z68 ATX Motherboard Combo
So do you have any other requirements for the motherboard besides aesthetics?nd any video card due to the fact that you're stil
I want to purchase these items tonight. I know that I have some strange reasons for what I'm getting (needing a good looking motherboard, and wanting 16GB of RAM).
Motherboard:
$178.00 - GIGABYTE GA-Z68X-UD3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
RAM:
$180.00 - G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video:
$195.00 - EVGA SuperClocked 01G-P3-1461-KR GeForce GTX 560 (Fermi) 1GB 256-bit
CPU:
$195.00 - Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core
My main questions are:
(1) Is everything compatible?
(2) Is there something completely obvious that I should do differently?
(3) Is there any difference between these two CPUs?
A Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core
B Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core
Motherboard:
RAM:
Video:
CPU:
The difference between the 2500 and the 2500K is the degree of maximum overclockability. The plain 2500 is only limited overclock capable while the 2500K is overclockable up to the CPU's practical limit. The plain 2500 is electronically limited to a maximum overclocked speed of 3.8GHz (38x) with all four cores in use to 4.1GHz (41x) with just a single core in use - while the 2500K can theoretically be set to run as fast as 5.7GHz (57x).
