Computer build advice
Please can somebody give me some advice as to this system... thank you
CPU: AMD Athlon 64 X2 3800+ Processor Socket 939 w/fan
Mobo: Asus A8N-SLI Premium nForce4 SLI Athlon64 (FX)/Sempron/Athlon64 X2 Skt939 DDR w/Audio, Dual Gigabit LAN, RAID/Serial ATA
V/Card: Asus EN7800GTX/2HDTV/256/Geforce 7800GTX 256mb GDDR3 PCI Express x16
TV Tuner: Asus TV FM Card 7135 w/Remote
Case: Aerocool AeroEngine II Mid Tower Case (Black)
DVD: BenQ DW1625 16X Dual Layer DVD +-RW Drive (Black)
Memory: Crucial Technology CT6464Z40B 512MB DDR400 PC3200 (x2)
HD: IBM Hitachi Deskstar 7K250 160GB Serial ATA 7200RPM
Screen: Viewsonic/ VX724/ 17-inch/ SXGA/ 1280x1024/ 4ms/ Analog/ DVI/ Black & Silver/ LCD [note I prefer 17" to 19" and this is the only 4ms monitor I can afford]
FD: Ultra Black 3.5" Floppy Drive with Built-in 6-in-1 Flash Card Reader
PSU: FSP Group (Fortron Source) AX500-A ATX 12v 500W 115/230 V Blue Storm
Keyboard: Adesso
Mouse: Razer Plasma Diamondback 1600dpi
Thank you
Skye
( -.-)zzZ
o_(")(")
sleepy jazz bunny
They have up to at least DW-1640
5:4 screens are the devil!
Floppy drive? What's that? :D
For a TV card, I'd probably go with something from Lifeview (Flyvideo), but meh.
Doesn't look so hot to me, but maybe it's one that does way past spec
If you plan on adding PVR functions in the future, please don’t get that card!
Yes a pvr-150 retail costs twice as much (~$90), but works ten times better and you can look for a rebate.
It comes with remote and IR blaster. It can be used with all the major PVR apps like GB-PVR, SageTV, etc.
If you are buying this for the cool light scribing feature, remember you need special disks for that and the scribing is slow as hell. You can save some money buying a the highly rated NEC 3540a for ~$40 bucks.
Floppy disk? Haha!! :p
Well I guess you must need the card reader, so ok. :)
