Complicated question
Jzegers24
Can a P5k delux mobo do this kind of setup?
What im looking to do is raid 2x raptors in raid 0
Then in another array, im looking to do a raid 5 with 3x 320gb hds for storage.
Is this possible with just the P5K delux mobo?
I don't think it matters if it will b/c I wouldn't trust it.
If you plan on setting something like that up I would highly suggest a dedicated RAID card.
agreed, I think you will run into some issues data corruption being namely one. Raid cards on the Egg' arnt too bad, I would look there
yes a raid card may be helpful but do any of you know if this is possible with the onboard raid?
what a load of horse shit.
Yes the ICH9R support 6 sata ports and any combination of raid 0 1 and 5 arrays. Raid 5 is limited to a max of 4 disks. So a two drive raid 0 and a 3 drive raid 5 is easy.
