Complete my build!
InfernalMachine
All of the above; it's a general purpose machine with a heavy lean towards PC gaming, specifically MMORPGs.
Bang for the buck within an unlimited budget but just because I can spend it doesn't mean I want to.
3) Where do you live?
Austin TX - No microcenter =(
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
PSU, CPU, MOBO, Case
Case: I'm torn between the Silverstone RV02 and FT02 but I'm more concerned about the internals at this point, I've also had my eye on the LIAN LI PC-A05NA as the space for the rig is somewhat limited.
Dual ATI 512MB 4870s
8GB (2 x 4GB) CORSAIR Vengeance 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
1x Corsair Force CSSD-F120GB2-BRKT 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD) (boot)
1x WD Velociraptor 300GB
1x WD Raptor 74.3GB
(most of my data is kept on my 4tb NAS, would like to pick up a cheap'ish' 1TB drive in the future, i've 2x 320GB Maxtor Diamond Max drives kicking around as well).
6) Will you be overclocking?
I'll be dabbling to see what I can get but it's not a focus of the machine.
24" 1920x1080 (res I use) - always want to have more or go bigger in the future.
Soon! I'm picking items up as deals pop up.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No need for Raid (have a NAS) or Firewire and don't NEED to have dual card solution; i'm totally fine with a single card solution in the future but would eventually run a dual card setup.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Win7U64
What I want is a QUIET PC (hence the corsair cooler and Silverstone cases) for a change without too much sacrifice in performance. I don't need e-peen framerates
I'm looking to build around a 2600K+.
$385 - Intel Core i5-2500K CPU + MSI P67A-GD65 Intel P67 ATX Motherboard Combo
$136 - Corsair 850TX 850W PSU
Total: $521 plus tax and shipping
Thanks, Danny! I've been cruising NE for deals that fit all week.
However, I'm leaning towards the 2600K and really want a modular power supply.
You're mainly gaming so no need for the 2600K unless you're doing extensive video editing or 3D rendering or something.
As for modular PSU, I recommend these:
$104 - XFX P1-650X-CAH9 650W Modular PSU
$102 - XFX P1-650X-CAG9 650W Modular PSU
$126 - Corsair 650HX 650W Modular PSU
$140 - Seasonic X650 Gold 650W Modular PSU
$136 - XFX Black Edition P1-750B-CAG9 750W Modular PSU
$150 - Corsair 750HX 750W Modular PSU
$165 - Seasonic X750 Gold 750W Modular PSU
$175 - Corsair 850HX 850W Modular PSU
$190 - Silverstone ST1000-P 1000W Modular PSU
$220 - Corsair 1000HX Modular PSU
