Compiz-fusion difficulty
SmokeRngs
[H]ard|DCer of the Month - April 2008
Okay, I've been using compiz-fusion for a while now and I've had the same little annoying problem the whole time. I've gotten to the point where I'm not going to use it until I can figure out the problem/setting/error or whatever it is. I like messing with it but this one little problem is just too annoying.
I'll start with the basics. This is on the machine in my sig which is running a 19" CRT as the primary display and a 17" CRT as a secondary display off the 7600GT. Currently, I'm running openSUSE 10.3 x86_64 with KDE.
Now, to the annoyance. Technically speaking, everything is working fine. However, when restoring a window from the taskbar I get a pause of about 1-1.5 seconds or so. I haven't timed it exactly. I also get the same thing with only some menus. Any right click menu in Firefox has the same delay as well as choosing any of the menus such as file/edit/view/etc. I get this in some other programs as well. It's not in every program, though. The KDE menu does not suffer from this problem or things such as the right click menu on the desktop. The final point about this is that it only happens on my primary display. I do not have this delay on my secondary display.
Both displays are setup the same in compiz with no differences. I've gone through every setting one by one on all of the active modules in compiz and everything is the same between the two. The main display being screen0 and the secondary display is screen1. I've also tried disabling I think every module I would have running normally and that did not change anything.
Has anyone else heard of this delay problem happening on just one display? I assume it's something which can be fixed or a setting which can be changed because it only happens on the main display. I would appreciate any help anyone could give.
sounds like an advanced effects problem.
I fought with something similar in ubuntu 7.10 until i installed the advanced effects control panel, and then edited each one until it did what I wanted
in ubuntu land, it's called "compizconfig setting manager" Not sure what it is in opensuse.
The CompizConfig Settings Manager is what I'm using to manage the effects. I have not tried to disconnect one of my monitors and really don't plan to just to see if it's also a problem with just one display.
Do you have them set up as separate X screens or are you using TwinView?
