Compatible motherboard need help?
crankypsp
Im planning on doing an athlon II build soon, but i need to know which mobos(reliable ones) would work with these cpu's right out of the box-without a bios update.
any suggestions?
Good rule of thumb would be to check out the CPU/mobo combo deals with the CPU you want over at newegg. My assumption being that newegg would only pair the mobo and CPU together if they worked together out of the box.
