I'm working on making a new system for gaming/personal use. I was wondering if some of you could take a look at it and let me know if you see any glaring problems with my plan that I might have missed (too weak PSU, wrong RAM for mobo, etc). Thank you!
AMD Phenom 9950 BLACK EDITION 2.6GHz Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103273
MSI Platinum AM2+/AM2 AMD 790FX ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130136
SAPPHIRE Radeon HD 4870 - 512MB Video Card (x2 - 1GB total)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102748
Rosewill 600W SLI Ready-ATX12V V2.01 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182032
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM 800 (PC2 6400) Dual Channel (x2 - 4GB total)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145177
WD 500GB 7200 RPM 16MB Cache SATA Hard Drive (x2 - 1TB total)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
ViewSonic VX1932wm 19" DVI Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116088
Rosewill ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147057
The estimated total price (after rebates, instant savings, and shipping costs) is about $1400 from NE. Does anyone know of any place that I can find any of the parts for less money, or more importantly (as I mentioned before) - any problems with compatibility, etc?
I should probably point out that I am planning to run XP Pro 64-Bit for the time being (since I already own that) - and then will purchase the next generation of windows that is slated to come out in the relatively near future.
Thank you all for the help!
