Compact Presario V2000 screen problems.
Red~Mage
So I'm having this issue with this laptop's display. The screen is incredibly dark and I can just barely make things out (helps if I use a flashlight). I thought it might be the blacklight at first, but If I press the stand-by button, I get a clear picture (if only for a second). It also works fine if I use an external monitor.
What could be causing this?
It's a typical defect problem w/ Compaq cheap end screen. There is nothing you can do, replace it under warranty.
Buy the business class 3 yr. warranty laptop in the future
either buy a NW or NC series HP business class machine from now on, or check your method of payment. IF you pay by credit card, most credit card c/w 1 yr. extended warranty
How incredibly bizarre.
I had been using it with a secondary monitor for a while... when my battery died I began charging it and it the monitor suddenly started working again. Thanks for the suggestions though, I'll keep it in mind next time I decide to buy a new laptop.
