Compact Micro-ATX case
  • Thread starter Deleted member 305099
  • Start date
D
Guest
I have a small home server built into Bitfenix Phenom M case. It serves the purpose, but the build quality (aside from the frame or something) is nothing short of horrible, cable management is impossible, and generally I shouldn't had bought it.
I need something of similar size, but better. I only need room for three disks, there will never be more.
I was looking at Fractal Design Node 804 and while it's a viable option, it's a bit too large (but acceptably so if needed) and it was way too many disk slots.
Is there something inbetween of these two maybe?
Is there something in between of these two maybe?
I went with the newer model of the Fractal Define Mini C. That is the one w/o the 5-1/4" bays in front, so it is shallower than the previous variant of the Define Mini. For the gaming PC build my ASRock Extreme 4 has two M.2 PCIe SSD drives. The only moving parts are the MB controller fans.
Fractal Define Mini C:
  • 3,5" HDD positions (2)
  • 2.5" HDD/SSD positions (3) (maximum 2.5" drive thickness is 10mm)
BTW - I have both Define mini models, the previous Define Mini is part of my family home PC and has a DVD drive installed.
3 discs? What size? 2.5" 3.5" ? Most cases I've seen have 2x3.5" max, so it might be a challenge to find 3x3.5" and keep it small at the same time.
I ended up buying discounted Node 804. I would have liked 140mm fan in the motherboard area instead of 120, but hopefully it will be ok, although that damn HBA card gets hot as hell.
