Comp Shuts Down Randomly
swatcatpettus
I have a brand new comp, specs are in sig, but about once every 3-4 days it will just power off. It did it again 10 minutes ago, and when i tried to boot it back up the spu fan spun halfway then stopped, it wouldnt boot, but it did the second time. I dont think this is a software issue, because it seems like something to do with power since everything just goes off, can anyone help?
Ultra X-Connect PSU's suck. I think that MAY be your problem.
Are you overclocking? I get this problem when I'm running on the fringes of what my RAM can handle.
Does sound like it coud be a power problem. The wife's machine started shutting down under heavy 3d gaming, mainly in WoW. Turns out it was the crappy 450w psu I had in there. A new Tagan 480W did the trick.
Do you have an auto-shutoff on overheat setting in your BIOS?
Could either be a false reading/faulty sensor or a real overheat somehow?
the cpu is usually never over 75%, it only does that when installing something or opening a big program, im a hard core cs player, 5+ hours a day, and the machine never shuts off during the gaming, it usually shuts off when im running trillian convo windows, maybe it is the ultra x cpu, but i doubt it, the cables are firmly in place, and it looks so gosh darn pretty i would hate to replace it and put ugly power cables everywhere, for overheat concerns, the case temp is never over 23 C, although it could very well be the cpu and heatsink, but again, its all brand new > 1 month old
When troubleshooting, the words "doubt" and "pretty" are some of the last ones that should be used when diagnosing. My suggestion also goes for double checking the power supply. Grab a multimeter, check for stability on the rails. Also make sure that you've got your PC plugged into a good UPS with a voltage regulator. Check to make sure the motherboard isn't shorting on the case.
All the signs point towards something power related. Maybe it's a defective unit with a faulty capacitor, maybe there's nothing with it at all, but never write something off under the pretense of "I doubt it, because it looks pretty".
Generally speaking, the best-performing PSUs are among the ugliest-looking beasts, while the prettiest-looking PSUs are among the worst performers at each given wattage rating. All that money that Ultra spends on looks causes the manufacturer of that PSU to cheap out on its innards. With the X-Connect, you will never know what you'll get from that so-called "500W" PSU. It could perform as badly as another company's 300W unit, for all I know. Also, the blue light on that PSU can suck up a lot of juice, leaving little power left for the rest of your computer. Thus, the "500W" rating on the X-Connect includes the wattage used to power the built-in blue light in the PSU. And that's flat-out cheating, as far as real power specs are concerned.
At least that X-Connect PSU will shut itself off if any overloading takes place. That way, you're unlikely to get the rest of your rig blown out along with a blown-out PSU.
The light would hardly draw any power, its a tiny light, it prolly draws less than 10 watts
I bought a cheap-0 580w PSU and had the same rebooting problem with my system and it ended up not being able to power my 6800 Ultra.. I just got an antec neopower 480 w and no more rebooting system, my video card works again, and it's super smooth.
Crazy huh!? ^_^
Even with that light, I still think that whomever made that X-Connect PSU cheaped out on its innards or put in an oversensitive auto shut-off switch... ;)
Even the specs don't calculate properly for that Ultra X-Connect 500w. Claims 500w max combined power output, but with the follow power table:
+3.3v - 28a
+5v - 30a
+12v - 34a
-12v - 0.8a
-5v - 0.3a
+5vSB - 2a
Just taking the 3 core voltages, +3.3, +5, and +12, calculating watts by multiplying volts times amps, I get a combined total of 650.4 watts... Something's not right. I have an older system with a Barton 2600+ on a Asus A7V333 mobo, with a Thermaltake TR2 430w with the following specs:
+3.3v - 20a
+5v - 30a
+12v - 18a
-12v - 0.5a
-5v - 18a
+5vSB - 0.8a
Using the same formula, the same 3 rails calculate to 432 watts.
Your X-Connect may be pretty looking, and modular, and blah blah blah, but everybody here is telling you that the first place you need to look is your power supply. I would recommend listening to the people who have more experience with this kind of issue, rather than arguing with them about a LED.
swatcatpettus, buy a REAL power supply, give it a try, and if you're still having problems, feel free to come on back and shock the hell out of all of us with your story.
The Wattage calculations work out that way becuase the Ultra X Connect PSU's list the default Wattage but can supply 650W peak. The PC & C 510 SLI I have can do 650W peak but it rated at 510W.
The ocz modstream is modular, looks pretty and of good quality. Check one of those out if you find you need to replace your ps. I am sure there are other alternatives as well, I am biased towards the ocz's as I have a powerstream and love it.
