mayakindaguy
- Jan 28, 2004
my system crashes like every few weeks giving the message fatal error upon reboot. the error detail says something about a minidump and it gives some weird directory i can't find or don't know how to find like c://doments/kenshin/locals~1.....something minidump or mini.
my cpu temp goes from 28 idle up to mid forties at the highest when playing games. mobo temp usually 38 to 40s
cpu fan is blazing a bit at 4200 but that may be cause i didnt get a chasis fan or power supply fan and im running with an open case..hope thats ok for now.
voltage 12, 5 , 3.3
vcore ranges from 1.58 to 1.64 which seems a bit high but it is stock and i dont know how to change.
ram is pc3200 kingston value at 3-3-3-8-8
any ideas why my system is so unstable at stock settings?
thanks
voltage 12, 5 , 3.3
thanks
