TheGoat Eater
- Nov 26, 2005
they are now in the US - they had 2 PCs at Showdown LAN Peoria,Illinois over the weekend... They are not painted - it is dye sublimation printed on a special fabric that is stretched over the case then baked on giving it a powdercoat type of finish - it is very durable and hard... If you have any questions I am sure I can get them answered...
C-kin skin Library
you must own a case or PC (either with your system or sourced case ) to buy the additional side panels to customize your case(aside from the original artwork panels )
Some Pics
(from the LAN)
C-kin skin Library
Some Pics
