I would love to have your comments on this build/parts i'm putting together for my next build. Better/cheaper parts are welcome please provide links if you do. This build is mostly for gaming, not much multi-tasking. Will be using a GF7950 video card until i get enough money for a 8800GT. Flaming is also welcomed
i like constructive criticism
case = Apevia x-qpack2 http://www.newegg.com/product/product.aspx?item=N82E16811144139
motherboard = Abit Fatal1ty F-I90HD http://www.newegg.com/product/product.aspx?item=N82E16813127023
CPU = Intel core 2 Duo E6550 http://www.newegg.com/product/product.aspx?item=N82E16819115030
RAM = OCZ Reaper HPC Edition 4GB (2x2GB) DDR800 http://www.newegg.com/product/product.aspx?item=N82E16820227267
RAM option 2= Crucial Ballistix 2GB (2x1gb) DDR2 667 http://www.newegg.com/product/product.aspx?item=N82E16820146567
the crucial is way cheaper than the ocz and is highly recommended from ppl here that have good results with it.
BTW this will be my 1st intel build, so please bear with me, its so differant than a AMD build/overclocking.
thanks
Winhyun
thanks
Winhyun
