Looks like my Commando has a problem. LED display shows CHIPINIT. I tried to check the ASUS site but it is down. Anyone know what it means? Doesn't sound good!
Yes the rig in the sig using 902 BIOS. I was adding a new HD to RAID array (to hot swap), uses an Areca 1210 card. Everything fine to that point. Been running sweet for several weeks after the install and overclock.
Thanks for the link kirbyrj. Was about to pull the battery but all I see is is the CMOS push button so can't leave it set off. I'll take a look see to see if there is a way to leave it in the reset mode and I missed. I'll also swap out the RAM just in case.
