Combining Forces!!!
micaknkt
How cool would it be to create a case that has a pc, xbox360 & ps3 compact as possible for easy of travel :confused: I had my xbox in my pc case before:D, but it wasn't very easy to cary around:(, it would have to be designed from the ground up:). Anyone use google sketch, it's frickin awesome!!! Any thoughts...
Hmm, the PC would most likely have to be a SFF system since ease of travel is a priority/goal.
you'd need to have a amazing cooling system, the xbox 360 doesnt like heat and the ps3 creates a lot of it.
I was thinking about using a nice matx board that has one pci-e slot and instead of having the card stick straight up from the board like ussual, I would make a custom slot expansion that would make the card parallel the motherboard!
That allready exists
It's called a PCI-E Risercard
Portable.... computer xbox and ps3... you might be able to make it portable but its going to be heavy
