Cold Winter by C4B
C4B
Hello!
I recently finished two mods, CURV3D and F4DE, one scratchbuild and one casemod. So now Im going to work on a older scratchbuild that I want to upgrade and also fix the small mistakes I did before. And I want to share this build at this forum!
This time I will also add a custom watercooling loop and other goodies.
EKWB! Thank you for helping me.
Be Quiet sponsored me with a Shadow Rock 2.
Gigabyte sponsored me with a GA-F2A88XN-WIFI.
MNPCTech sponsored me with this fan grill to have in the front, should look awesome!
Clear Acrylic 120mm Overkill "Nautilus" PC Fan Grill from Mnpctech.com
Well lets start by some pictures of the parts of the case that I have to work with right now.
It consists of the parts, the frontpanel, the sides and the backpanel. All together it creates a nice shaped case.
As you see the acrylic is kind of rough, many scratches. So I will start working on that. The acrylic part didnt really fit perfect either as seen on this picture:
So I measured out and cut 4-5mm so it fits better!
I will install the motherboard on the right side of the acrylic, and because I dont want to show the backside of the motherboard through the acrylic I gave it some black paint!
Im currently planning on what kind of hardware and other stuff I will use in this project. The next thing I will do is to cut out a hole in the backpanel for the powersupply and start working on a shroud over the bottom part of the case.
Thank you for checking in! Please leave a comment.
With king regards
Johan Nyman
Minimalistic PC's
Neat! Are you going to backlight it? If so, what color? I think I'd go for cool white.
Lookin forward to seeing the completed build! :)
Me too! I will be making a aircooled version for Dreamhack, then after that I will start the real project and make a custom loop for it and so on. Thank you for your support Bill!
I rushed to finish a aircooled version for Dreamhack that was this weekend thursday, for a Gigabyte contest there. After that I will start the real project with custom loop and other goodies.
To start off:
What I started doing was to fix the 120mm hole in the front and also make the 92mm hole in the back to 120mm.
Then I started working on a shroud that would cover the powersupply. Used acrylic that I painted black on one side.
Then I painted the inside of the acrylic black too so it would hide the powersupply and everything else.
Then I added the fan grill I got from Bill. Looks awesome!
I got the motherboard and cpu down at Jönköping where Dreamhack is, so I installed everything there. It ended up looking like this.
And here it is together with all the other mods, I always ends up with the smallest mods haha.
So next thing to do is to make a watercooled version. I also have to get ahold of a CPU, I think Ill wait for the new AMD A10-7850K, should be released in January, the 14th I think. I was thinking of using a 50-60mm 120mm radiator in the front. Should be enough for the CPU.
So what did you think about the "aircooled Dreamhack" version of this mod?
With kind regards
Johan Nyman
Minimalistic PC's
Great job Johan, the display looks great too!
Thank you Bill!
Sorry for no updates here, but I have been waiting for the release of AMD A10-7850K, now it is here and I cant wait to start. Im still waiting for watercooling gear from EKWB though, after I got that I can start the casemodding for real. :)
I want to start by announcing a new sponsor and thank them for all their help, EKWB! Thank you for helping me and sending me:
  • 120mm XT Radiator
  • Supremacy Clean CSQ Nickel-Acrylic
  • RES X3 150mm
  • Fittings
I started out installing the loop to see how I wanted everything, the RES is installed in the top like this.
The 120mm XT rad goes in the front of course together with the DCP 2.2 pump on the bottom.
The entire loop from behind, whats missing here is the cover over the PSU and the pump, working on that right now aswell as fixing all the cables to perfect lenght.
I cant get a good photo from the side because of the tinted plexiglass, although, as soon as I have some lights inside the case there will be good pictures.
Last picture of the day!
What do you think so far?
I have dissassembled everything now to finish the last small details.
  • Complete the coverplate for the PSU and pump.
  • Fix all the cables to perfect lenght.
  • Install a SSD.
  • Leaktest.
  • OS Install and config.
Hopefully Ill have a new update this weekend, until then, have a good day!
With kind regards
Johan Nyman
Minimalistic PC's
The loop is filled with Mayhems, its leaktested and the computer boots up! This project is now finished. I took some pictures of the result, the final pictures will be taken tomorrow though, but here are some sneakpeaks.
What do you think?
With kind regards
Johan Nyman
Minimalistic PC's
Hello everyone!
So I finally finished Cold Winter, the third version. I went back and checked when I started the first project log for this case, 2011-01-04, a while ago. However, this mod has meant a lot to me, this was the second serious project I made and the first one I was really satisfied with. Since then I made a second version and then started planning a third version that I promised myself was going to be the last, and here it is!
The sad part is the scratches on the acrylic, this was made when I built this case at my school, someone there thought it was funny to start etching stuff on it, the same happened at Dreamhack. So sad, I tried as good as possible to polish it but not with a really good result. The good part is that isnt really easy to see if you dont put a light right on the scratches.
I want to say thank you for all the nice comments and feedback of Cold Winter and I also want to give a big shoutout to the sponsors for helping me with the hardware!
Well do you want to see the final pictures? Here you go! :)
Ill be back here with more updates on other projects. Until then, I would be happy if you would like to check out my facebook-page where I post all my projects, updates and giveaways. Check it out and like it. :)
Thank you everyone!
With kind regards
Johan Nyman
Minimalistic PC's
Really nice build man. Very slick. I like that it could fit a decent GPU as well...obviously not what you were going for though since there are water cooling tubes looking all awesome in that spot now :D. I'm sure a variant this case would have destroyed the prodigy if it had been available.
Yeah it isnt a problem to install a graphics card, just didnt want to. I think even a matx motherboard would fit in this case. :)
