hey guys, I've come across an odd problem and I need some help.
I've put together a build for a coworker and just installed Win7 home prem 64
All windows updates are done.
The problem:
Half the time when the computer is started from a cold boot, the windows loading screen appears, acts normal, then the display goes black.
The LCD blinks "no signal". If I hit the reset button, it resets, then boots normal (but reports windows did not load properly last time).
Other times, it starts fine. I played games on the comp for about 8 hours over the weekend and never had a problem during gameplay.
When I F8 to boot using low-resolution mode, it works fine.
Could this be a Catalyst driver problem?
The system specs
Corsair Spec-03 case
Corsair TX 750w psu
Intel i3-2100 w/stock hsf
Biostar TZ77XE3 motherboard LGA1155
2x4gb Corsair XMS DDR3 1600
Seagate 240gb Pro ssd
XFX Radeon 280x DD (catalyst 14.4)
Seagate 3TB hdd
LCD temporarily for setup is a Dell 24" 1920x1200.
I know the psu, cpu, mobo & ram are not defective because I used them for almost a year.
I'm going to try uninstalling the catalyst 14.4 then installing catalyst 13.9
The problem:
The system specs
Corsair TX 750w psu
Seagate 3TB hdd
