Kern said:. And hey, if it gets hot, I'll just drop and ice cube in there!
Drop a few cubes and some gin and ur cooking!
looking good so far and u cant beat the price. Keep up the good work, and the pics.
Kern said:Thanks! I had the idea in my head and worked out and zer0signal showed me one he had like it. I think it will work out real slick and should be easy to fill. I'm going to cut a hole in the top of the case and put the top of it out, so filling and bleeding shouldn't be a problem. And hey, if it gets hot, I'll just drop and ice cube in there! Convenient! Or... condensation... oh well!
killernoodle said:Here is a tip: dont get a used radiator.... worst idea ever. '77 bonneville HC should suit you nicely.
Rads said:I just went there the other night and they've got clear coat too for like 97 cents.
Kern said:More to come soon! I just bought a Mag3 pump off a guy from the forums, so that should be here soon. I should also have my water block purchased in a few days, and then it's cutting time! Actually, I've already hacked up the inside of the case (as you can see).
Until next update!
Kern
Spidey329 said:I made my shroud out of double-thick cardboard. Booyah, cost = $0!
cornelious0_0 said:Haha, I did the same thing when I chopped up one of my NV5's for fun and made a custom shroud for it for use with my SmartFan II.....good fun.
tsuehpsyde said:Bah, I hope this project doesn't die I've been looking foward to it's build and conclusion, seeing as how my next build I might get enough courage to water cool
Thats what I've been waiting to hear! (Eagerly awaits next update...)Kern said:And just so you all know, total was pretty much under 100 dollars!
