Albert Silver
- Oct 1, 2005
Just a word of warning. While researching for the right 19-inch LCD for myself, I have naturally been culling information from numerous sources, one being the very conspicuous CNET. I say conspicuous since their reviews appear everywhere from Business Week to the NY Times. Unfortunately the quality control seems to have gone down the drain, and don't think I'm pitting my opinion against theirs.
First I ran into a review on the Syncmaster 930B which not only shows a performance chart of the 915N, but even concludes the review discussing it instead.
Later, I decided to check up on the Sony SDM-HS95P and was flabbergasted to see the review of a 17-inch model instead. Wondering whether there was a switch around, I soon found that the same review was attributed to no less than 11 products as can be seen here.
I reported the incidents of course, and they said that someone would be in touch with me and that the problems would be addressed. Needless to say, not only did no one contact me, but I now received notification that CNET regards the issues as SOLVED (their capital letters, not mine). Note that not one of the "reviews" were fixed.
Cheers,
Albert
Cheers,
Albert
