CMOS reset required?
nitz12
Hello,
I have 4GB OCZ PC2-8500 DDR2 Dual Channel Reaper Series 1066MHz CL 5-5-5-18 that replaced 2GB 800MHz Corsair 4-4-4-12. Do I need to reset the CMOS to ensure that the settings for the new memory take effect, or does that have no pertinence here? And should I set my BIOS to the exact timings the sticks are for, or is there some kind of adjusting that would noticeably improve performance? For my configuration, what would the correct voltage settings be?
Thanks for your help.
unless you manually set the corsair memory then you should not have to reset the bios.. but if you want you can.. and yes.. if the bios dont correctly set the speeds to 1066 @ 5-5-5-18 timing.. then you will have to do it manually..
You will most likely have to set those timings manually. Default is usually 5-5-5-15 at DDR2 800 speed and 1.8V. If you want anything more aggressive (as I assume you do with 1066 memory), you'll have to set it manually.
Set the memory timings to auto, they will then start running at the rated timings for the frequency you use, as defined/stored on the memories SPD chip.
You can then change them to what you like after, this is a quick way to get the memory timings into the right ballpark.
