CMOS checksum?
Atherton213
everytime i turn on my computer it says CMOS checksom error... press f1 to continue... so i do and it turns on a works like normal?... what does that mean???
just did that.. .and still... actually been through 2-3... always update to the latest
Have you tried resetting the CMOS and/or resetting your bios to default settings? I've seen that several times and one of those two always fixes it for me....
Are your setting saved when you continue? Do you lose any custom settings?
ill try reseting it... but i dont have any custom settings... just have it set to default so really its not big deal... just wondering what it was? if it was bad or not... ill try everything said....how do i reset the cmos??? just take the little battery out?
info on my board is the gigabyte k8ns-939-ultra all jumpers are where they were when i got the board havent touched them
I'd also try replacing the battery, might be dead and not keeping the settings.
There should be a jumper on your mobo that you switch positions on and it will clear the CMOS. Check the manual for your board. Taking the battery out will also work.
