CMOS checksum failed msg after flashing P5BD
Hiyruu
So I decided to flash my Asus P5B Deluxe to 0711.
I used the latest version of AsusUpdate, and it flashed it fine, but when I rebooted I got a message saying something like, CMOS checksum failed, and something about overclocking failed, then it had 2 options, F1 to enter setup I think, and F2 to load defaults, or something like that.
So I pressed F2 and my system loaded normally, and everything seems fine, I used AsusUpdate to check my BIOS version, and it says that now it's 0711.
So, is this whole incident normal, or what?
Thanks for any help.
Normal after an update, when flashed some setting were changed due to the flash and thus when rebooting the computer noted that the new settings did not match the old settings and kinda forced you to go in an take a look-see.
No worries. My gigabyte will do the same thing, If you set your bios to "factory defaultsl" before you flash it (most boards) it wont do that but again, its not a big deal.
either way and it kinda depends if you were overclocking or you had made some personal changes to the bios values.
the defaults (F2) will give reliable stable operation but might not provide the optimal performace with your particular hardware setup.
I would reboot and go into bios and look for :
If you have a "load optimal values:" option available on the bios menu and had not made changes yourself , I would load "optimal values". then just save and exit.
if you do not have something like "optimal values" and have not made any personal changes, just exit out and run with the defaults.
If you had gone into bios and made changes for overclocking or other reasons you need to go into the bios and check that everything is the way you want it.
I've never changed anything in the BIOS except for the boot order.
I didn't see anything about 'optimal values' in the BIOS.
