I just bought a new ABIT NF7-s v2 and AMD XP Barton Mobile 2600+ and installed everything. Thermalright heatsink on top. Everything fit perfectly and the cpu fit in the socket just fine.
CPU: AMD XP Mobile 2600+ (Barton)
MOBO: ABIT NF7-S v2
RAM: Micron PC2700 (DDR333)
I booted up and the bios loaded and it says
"Main Processor: Unknown CPU Type (600MHz)
Memory Testing: 524288K (Ok)
Memory Frequency for DDR333
DDR Dual Channel Enabled
Primary Master: xxx
Primary Slave: none
Secondary Master: xxx
Secondar Slave: none
CMOS Checksum Error - Defaults Loaded"
Then I clicked F1 to see what would happen and it did some test and said..
"NTLDR Missing"
Then i rebooted and it said
"Same as above and..
CPU is unworkable -Check Softmenu"
Can someone help me?
MOBO: ABIT NF7-S v2
Primary Master: xxx
Primary Slave: none
"NTLDR Missing"
