Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
and when the computer boots up, it says BAD CMOS BATTERY
and CMOS MEMORY WRONG
and it says
press F1 to enter setup
Press F2 to contine the default settings.
and everything works. ok
but why does this say this. the bios is set up to the default config
and everything
i already went out a got a new battery. cleaned the contacts with Qtips and diped them in acoloho. still says
the it actualy says
"CMOS Memory Size Wrong"
Did you try clearing the CMOS after replacing the battery? Should be a momentary jumper you need to short. Seems like it should have cleared itself without a battery though.
